Welding Industry Acronyms
If you are involved in the welding industry you are constantly surrounded by all sorts of acronyms.  Below is a list of the most commonly used abbreviations in our industry.
ABS         American Bureau of Shipping
AC          Alternating current
AlSl         American Iron and Steel Institute.
AL            Aluminium
AMP      Amperes (measure of current)
ANSI      American National Standard Institute.
Ar          Argon (inert shielding gas)
ASM      American Society for Metals.
ASME    American Society of Mechanical Engineering
ASTM    American Society for Testing and Materials.
AWS      American Welding Society.
BS           British Standard.
BV          Bureau Veritas (French classification institute)
BZ           Brazing
CE           Equipment with CE-markings fulfills the basic requirements of the Low Voltage and  Electromagnetic Compatibility Guideline.
CSA        Equipment with CSA-Test mark fulfills the requirements made in the relevant standards for Canada and the USA.
CO2        Carbon Dioxide
CTWD    Contact Tip to Work Distance
CWE       Certified Welding Educator
CWI        Certified Welding Inspector
CWB      Canadian Welding Bureau
DC          Direct Current
DCEN     Direct Current Electrode Negative polarity (DC-)
DCEP                     Direct Current Electrode Positive polarity (DC+)
DNV                       Det Norske  Veritas (Norwegian classification institute).
EN                          Euro Norm (The European Community for standardization has developed a nomenclature in welding)
ESO                        Electrical Stick Out
FCAW                    Flux Cored Arc Welding
FCAW-GS            Flux Cored Arc Welding – Gas Shielded
FCAW-SS             Flux Cored Arc Welding – Self Shielded
Ft-Lb                      Foot Pounds
GMAW                 Gas Metal Arc Welding
GMAW-P             Gas Metal Arc Welding Pulse (transfer)
GTAW                   Gas Tungsten Arc Welding
He                          Helium
In                            Inches
IPT                          Inter Pass Temperature
LR                           Lloyds Register of Shipping (British classification Society)
MAG                     Metal Active Gas (see also GMAW).
MIG                       Metal Inert Gas
mm                        Millimeter
MPa                       Mega Pascal
MT                         Magnetic Particle Testing
NDT                       Non Destructive Testing
NS                           Norwegian Standards Association.
NSFI                        Norwegian Research Institute for Ships.
O2                          Oxygen
PAW                      Plasma Arc Welding
PPM                      Parts Per Million
PQR                       Procedure Qualification Record
PWHT                    Post Weld Heat Treatment
RT                          Radiographic Testing (X-ray)
SAW                      Submerged Arc Welding
SMAW                  Shielded Metal Arc Welding (stick welding)
TIG                         Tungsten Inert Gas (See GTAW)
TS                           Travel Speed
UT                           Ultrasonic Testing
V                             Volts or Voltage
VT                            Visual Testing
WFS                       Wire Feed Speed
WPS                       Welding Procedure Specification
Did we leave out any commonly used acronyms? Do you have an acronym you need help with?
13 thoughts on “Welding Industry Acronyms
    • IPM = inches per minute (used in welding travel speed and wire feed speed)
      PPE = Personal Protective Equipment (safety glasses, welding jackets, steel toe boots, respirators, welding gloves, welding hoods, etc.)
  1. Noticed this on my review form can you tell me what the difference is, please. GMAW and GMAW-S. I understood the S is for short circuit but what is GMAW referring to?
    • It refers to all other GMAW modes of metal transfer (globular, spray, pulsed spray). However, keep in mind that GMAW can also refer to short circuit transfer as it is still a mode of Gas Metal Arc Welding.
