Prequalified vs. Qualified Welding Procedures in the Real World
Prequalified welding procedures are often viewed as the easiest path to compliance.
When allowed by code, they can save time, reduce cost, and eliminate the need for procedure qualification testing. As a result, many fabrication organizations rely heavily on prequalified Welding Procedure Specifications to support production.
At the same time, prequalified procedures are also frequently misunderstood and misapplied.
This series is built around the reality that prequalification is not the same as simplicity. While prequalified welding procedures can be an excellent solution when used correctly, they still require engineering judgment, proper application, and a clear understanding of their limitations.
The articles in this series examine when prequalified welding procedures are the right choice, when they introduce risk, and when qualification testing is required, even if the governing code allows prequalification.
Who This Series Is For
This series is written for professionals who are responsible for selecting, developing, approving, or using welding procedures, including:
The emphasis throughout is not on reproducing code language, but on understanding how prequalification works in practice, where it adds value, and where it can create unintended problems.
Why Prequalified vs. Qualified Is Not a Binary Decision
One of the most common misconceptions in fabrication is that welding procedures fall into two clean categories:
In reality, the decision is more nuanced.
Prequalified procedures still require:
Likewise, there are many situations where qualification testing is unavoidable, regardless of what the code permits.
This series explores those decision points using real-world examples rather than theoretical explanations.
Articles in This Series
  1. When Prequalified Welding Procedures Are the Smartest Option
  2. How to Stay Within Prequalified Welding Procedure Requirements
  3. Why Some Welding Procedures Must Be Qualified, Even When Prequalification Is Allowed
  4. How Prequalified Welding Procedures Are Commonly Misapplied in Production
  5. Using AWS D1.6 Stainless Steel Prequalified Welding Procedures
  6. From Prequalified to Qualified: A Case Study in Speed, Quality, and Long-Term Savings
(This list will be updated as articles are published.)
Each article addresses a common misconception or failure point related to prequalified welding procedures and their use in production environments.
Free Resources for Additional Learning
If you want to better understand how prequalified welding procedures work and how they are developed under AWS structural welding codes, the following free resources are available:
These resources are intended to support learning and improve understanding before procedures are put into production.
Prequalified Welding Procedures – Ready for Immediate Use
In many fabrication environments, there simply isn’t time to learn how to write prequalified welding procedures from scratch.
For organizations that need ready-to-use, code-compliant procedures immediately, the following collections are available:
These procedures were developed by welding engineers and Certified Welding Inspectors and are in full conformance with their applicable AWS structural welding code.
They are designed to:
If you need compliant procedures now—and do not have the time to develop them internally—these collections provide a practical, defensible solution.
How to Use This Series
These articles are intended to be read in sequence. Together, they provide a practical framework for deciding when to use prequalified welding procedures, when qualification testing is required, and how to avoid common compliance and production pitfalls.
AWS D1.6 Structural Welding Code - Stainless Steel prequalified welding procedures                          AWS D1.1 STructural Welding Code - Steel Prequalified Welding Procedures
