Prequalified welding procedures are often misunderstood.
In some organizations, they are viewed as a shortcut—something used to avoid the time and expense of procedure qualification testing. In others, they are treated as a default solution, applied broadly without much consideration beyond whether the code allows them.
In reality, prequalified welding procedures can be the smartest option available when they are used deliberately and for the right reasons.
This article explains when prequalified welding procedures make sense, why they are often the best starting point, and how they can support both quality and speed without compromising compliance.
This article is part of the Prequalified vs. Qualified Welding Procedures series, which examines how AWS D1.1 and AWS D1.6 requirements are applied in real fabrication environments.
What Prequalification Actually Provides
Under some AWS structural welding codes, prequalification allows certain welding procedures to be used without procedure qualification testing, provided all applicable requirements are met.
What prequalified welding procedures really provides is:
- A defined framework of acceptable variables
- Proven combinations of materials, joints, and processes
- A clear path to compliance without testing
It does not eliminate the need for engineering judgment, nor does it guarantee that a procedure will work in every production environment.
When used correctly, prequalification is a risk-reduction tool—not a shortcut.
Speed Is Often the First Driver—and a Legitimate One
One of the most common reasons companies choose prequalified welding procedures is speed.
Fabrication schedules often do not allow time for:
- Developing procedures from scratch
- Scheduling procedure qualification tests
- Waiting for test results and approvals
In many cases, welding procedures are needed quickly to:
- Support bids or contract awards
- Begin production without delay
- Demonstrate compliance to customers or inspectors
When speed matters, prequalified procedures offer a code-compliant solution that allows production to move forward without sacrificing quality.
Prequalified Procedures Reduce Early-Stage Risk
Another major advantage of prequalified welding procedures is risk reduction.
For organizations without a welding engineer on staff, procedure development can introduce uncertainty:
- Are all required variables addressed correctly?
- Are code limitations being interpreted properly?
- Will the procedure hold up to review or audit?
Prequalified procedures reduce this risk by relying on code-approved boundaries that have already been validated.
This is especially valuable early in a project, when:
- Processes are still being established
- Personnel are learning new requirements
- Consistency has not yet been proven
Starting with prequalified procedures creates a stable baseline.
Quality and Consistency Benefit from Defined Limits
Prequalified welding procedures impose clear limits on:
- Joint details
- Base material groupings
- Filler metal classifications
- Welding processes and positions
These limits are not arbitrary. They exist to ensure predictable weld behavior and acceptable performance.
When procedures are developed within these boundaries, they tend to produce:
- More consistent welds
- Fewer surprises during inspection
- Better repeatability across welders and shifts
For many production environments, this consistency is more valuable than absolute flexibility.
Cost Savings Go Beyond Avoiding Testing
It is easy to focus on the direct cost savings of avoiding procedure qualification testing.
In practice, the savings extend further:
- No test material or machining
- No lab or NDT costs
- No engineer or technician time dedicated to testing
- No delays waiting for approvals
For organizations that would otherwise need to qualify multiple procedures, these savings can be substantial—especially early in a program.
Prequalified procedures allow companies to allocate resources toward production rather than qualification activities.
When Prequalified Procedures Are the Right Starting Point
Prequalified welding procedures are often the smartest option when:
- The applicable welding code or standard allows it
- Production needs to begin quickly
- The scope of work fits within code-defined limits
- Consistency and predictability are priorities
- Internal welding engineering resources are limited
- The long-term production strategy is still evolving
In these situations, prequalification provides a compliant, stable foundation that can support immediate needs while leaving room for future optimization.
Prequalification as a Strategic First Step
One of the most overlooked advantages of prequalified procedures is their role as a starting point, not a final state.
Many successful fabrication organizations:
- Begin with prequalified procedures to establish quality and compliance
- Gain production experience and performance data
- Identify opportunities for efficiency improvements
- Later justify qualification testing where the return on investment is clear
Used this way, prequalification supports both short-term execution and long-term improvement.
- Prequalified welding procedures are not shortcuts
- Speed is a legitimate reason to use prequalification
- Prequalification reduces early-stage risk
- Defined limits support quality and consistency
- Prequalified procedures often make the best starting point
This article is part of the Prequalified vs. Qualified Welding Procedures series.
Prequalified vs. Qualified Welding Procedures – Series Hub
Free Resources for Additional Learning
If you want to better understand how prequalified welding procedures are constructed and applied under AWS D1.1, the following free resources are available:
- How to Write AWS D1.1 Prequalified Welding Procedures
A practical overview of how prequalified procedures are developed and what the code actually requires. - Checklists for AWS D1.1 Qualification of Welding Procedures and Welders
Structured checklists to help verify compliance with AWS D1.1 qualification requirements and avoid missed steps.
These resources are intended to support learning and improve understanding before procedures are put into production.
Prequalified Welding Procedures – Ready for Immediate Use
In many fabrication environments, there simply isn’t time to learn how to write prequalified welding procedures from scratch.
If you need code-compliant procedures immediately, the following collections are available:
- 322 AWS D1.1 Prequalified Welding Procedures for Carbon Steel
- 280 AWS D1.6 Prequalified Welding Procedures for Stainless Steel
These procedures were developed by welding engineers and Certified Welding Inspectors and are in full conformance with their applicable AWS structural welding codes.
They are designed to:
- Save time
- Reduce risk
- Eliminate the need to interpret code requirements under schedule pressure
- Provide immediate coverage for common joints, materials, and thickness ranges
If you need compliant procedures now—and do not have the time to develop them internally—these collections provide a practical, defensible solution.
