5 Common Welding Symbol Interpretation Mistakes
Most welding symbol mistakes are not dramatic.
They do not usually involve completely unreadable drawings or obviously incorrect symbols. Instead, they are subtle misinterpretations—small details that are overlooked, assumed, or misunderstood. Over time, these small errors compound into inconsistent welds, unnecessary labor, inspection issues, and rework.
What makes welding symbol interpretation particularly challenging is that many people believe they understand symbols better than they actually do.
This article is part of the Welding Symbols: Where Interpretation Breaks Down series, which examines why welding symbols are frequently misread, misapplied, or misunderstood in real fabrication environments.
Mistake #1: Confusing Arrow Side and Other Side Requirements
One of the most common welding symbol mistakes involves misunderstanding arrow side versus other side requirements.
Many assume:
  • The arrow simply points to the joint
  • Weld requirements apply universally to both sides unless stated otherwise
In reality, the placement of the weld symbol above or below the reference line carries specific meaning. Misinterpreting this distinction can result in welds being placed on the wrong side of the joint—or on both sides when only one was intended.
Welding symbols - importance of weld symbol placement - arrow side, other side. Welding symbols interpretation mistakes
The placement of the weld symbol on the reference line dictates whether the weld is made on the arrow side (weld symbol below reference line) or on the other side (weld symbol above reference line)
This mistake often goes unnoticed until inspection or fit-up problems occur.
Mistake #2: Assuming Weld Size Means the Same Thing Everywhere
Weld size is another frequent source of confusion.
Common issues include:
  • Assuming on weld size and length
  • Ignoring differences between theoretical and actual throat
  • Misinterpreting size requirements when symbols are combined with length or pitch
Because fillet welds are so common, many people rely on habit rather than interpretation. This leads to consistent overwelding or, in some cases, undersized welds that fail inspection.
Understanding weld size requires more than recognizing the number—it requires understanding what the number applies to.
The size of a plug weld symbols is specified to left of the plug weld symbol. The pitch for plug welds is specified to the right of the plug weld symbol. Getting this reversed can be very costly. Welding symbols interpretation mistakes
Mistake #3: Misreading Intermittent Weld Symbols
Intermittent weld symbols are widely misunderstood, especially in production environments.
Typical errors include:
  • Confusing weld length and pitch
  • Assuming continuous welds when intermittent welds were specified
  • Ignoring staggered versus chain intermittent requirements
Intermittent staggered fillet weld symbol denoting length and pitch. Welding symbols interpretation mistakes
Many mistakes are made reading welding symbols when length and pitch are specified. Also, staggered intermittent fillet welds are specified when the weld symbols above and below the reference line do not line up. This is not a drafting error. They are placed staggered on purpose.
These mistakes often result in unnecessary weld metal deposition and additional labor—both of which increase cost without improving performance.
Intermittent welds are commonly specified to control distortion, reduce heat input, and manage cost. Misreading them defeats their purpose.
Mistake #4: Overlooking Supplementary Welding Symbols
Supplementary symbols—such as all-around, field weld, contour, or finish symbols—are frequently ignored or misapplied.
This happens because:
  • They are visually smaller
  • They appear secondary to the main weld symbol
  • Their implications are not always understood
However, supplementary symbols can significantly affect how a weld is made, finished, or inspected. Ignoring them can create conflict between fabrication and inspection requirements.
Supplementary welding symbols such as the filed weld (flag) and all-round weld (circle) are easy supplementary weld symbols, yet they are still misread often in a production environments. Welding symbols interpretation mistakes Supplementary welding symbols such as the filed weld (flag) and all-round weld (circle) are easy supplementary weld symbols, yet they are still misread often in a production environments.
Mistake #5: Treating Welding Symbols as Standalone Instructions
Perhaps the most fundamental mistake is treating welding symbols as isolated instructions rather than as part of a larger drawing context.
Welding symbols must be interpreted alongside:
  • Notes and general requirements
  • Joint details and sections
  • Material specifications
  • Tolerances and dimensional constraints
Welding symbols can make reference to other documents by having additional information in the tail section. The symbol above makes reference to a separate document, section A-A for additional informaiton regarding joint dimensions. Welding symbols interpretation mistakes
When symbols are read in isolation, assumptions fill in the gaps. This is where interpretation diverges and variability increases.
Why These Mistakes Persist
These interpretation mistakes persist because welding symbols are often learned informally.
Many professionals:
  • Were never trained in the full welding symbol system
  • Learned only the symbols relevant to their role
  • Rely on charts without understanding foundational rules
Without structured learning, people tend to apply logic or past experience where precision is required.
A Better Way to Reduce Interpretation Errors
Reducing welding symbol mistakes requires a systematic approach, not just better reference materials.
Effective learning typically follows this sequence:
  1. Understanding the components of a welding symbol
  2. Mastering fillet weld symbols and supplementary symbols
  3. Progressing to groove weld symbols
  4. Then addressing plug, slot, and specialized symbols
This same sequence applies to video-based learning. The following tutorials are designed to be watched in order:
  1. How to Read Fillet and Supplementary Welding Symbols
  2. How to Read Groove Welding Symbols
  3. How to Read Plug and Slot Weld Symbols
Each builds on the previous lesson and reinforces the symbol system as a whole.
  • Most welding symbol mistakes involve small but critical details
  • Arrow side and other side confusion is extremely common
  • Intermittent weld symbols are frequently misinterpreted
  • Supplementary symbols are often overlooked
  • Welding symbols must be read in drawing context
This article is part of the Welding Symbols: Where Interpretation Breaks Down series.
Welding Symbols: Where Interpretation Breaks Down – Series Hub
Learning and Self-Assessment Resources
If you want to identify where misunderstandings may exist, a free welding symbols test is available and can quickly highlight gaps in interpretation.
For structured, step-by-step learning, the Welding Symbols Training Manual provides detailed explanations, examples, and reference material that support correct interpretation in real fabrication settings.
Learning welding symbols is necessary for many professionals in the welding industry. From welders to welding inspectors, from estimators to quality personnel, knowing this language is an absolute necessity.
The Welding Symbols Training Manual  will teach you welding symbols starting from the most basic elements all the way to the very complex symbols. A total of 121 review problems provide plenty of opportunity to test your knowledge as you learn.
You will also get the Welding Symbols Guide  which will allow you to interpret welding symbols even before you learn this language. Simply find the type of symbol and use the graphical guide to determine the meaning of all the elements of the symbol at hand.
In addition to the 121 review problems in the Welding Symbols Training manual you also get a comprehensive, 40-question Welding Symbols Test to gauge your proficiency with welding symbols. (Answer keys are provided for both the review problems and the comprehensive test).
