As a dedicated welding professional – whether you’re a welder, a welding supervisor, a welding inspector, a welding engineer, a design engineer, or part of quality control (QC) – the ability to confidently interpret welding symbols is absolutely paramount for improving your job performance and ensuring superior weld quality. Even owners and executives in manufacturing businesses where welding is a core process benefit immensely from understanding these crucial technical details, influencing welding economics and mitigating weld failure.
In Part 1: How to Read Welding Symbols: The Basics, we laid the essential foundation, introducing the core components of every welding symbol. Then, in Part 2: Mastering Groove Weld Symbols, we dove deep into one of the most critical weld types used in heavy fabrication. Today, we’re tackling a specialized, yet equally important, weld symbol: Plug Welds. While they might seem straightforward, understanding their distinct weld symbols and specific weld dimensions is key to precise execution and welding inspection.
This guide will break down the complexities of plug weld symbols, ensuring you can read, interpret, and apply these instructions with precision. For a dynamic visual walkthrough and to solidify your learning plug weld symbols, don’t miss our accompanying video tutorial on plug and slot welds embedded below! This article is an essential excerpt adapted from our comprehensive Welding Symbols Training Manual, designed to simplify complex AWS 2.4 Standard Symbols for Welding, Brazing, and Nondestructive Examination technical information.
Understanding Plug Weld Symbols
A plug weld is a method of joining two members by creating a round weld through a pre-drilled or machined hole in one member, fusing it to the surface of the other member directly beneath. It’s a powerful technique for connecting overlapping plates or attaching components where access for other weld types is limited.
The plug weld symbol itself is distinctive: it features a simple rectangle, always accompanied by the
diameter symbol (Φ) placed directly to its left.
It’s crucial to differentiate a true plug weld from a fillet weld around a hole. A plug weld must always cover the entire hole with weld metal. However, it doesn’t necessarily have to fill the hole completely to the top unless specified. If the blueprint calls for a fillet weld made around the edge of a hole, you’ll see a standard fillet weld symbol – not a plug weld symbol. The intended weld type dictates the symbol, even if the hole’s physical appearance might be similar. This understanding is key for welder qualification and adherence to welding procedures (WPS).
Plug Weld Symbol Location Significance
Just like with fillet welds and groove welds, the placement of the plug weld symbol relative to the weld symbol reference line follows a consistent rule in welding symbols.
- If the plug weld symbol is placed above the reference line, it indicates that the hole and the subsequent weld are to be made on the other side of the joint (the side opposite to where the arrow points).
- If the plug weld symbol is positioned below the reference line, the hole and the weld are to be made on the arrow side of the joint.
Specifying Plug Weld Size
The diameter, or weld size, of the plug weld is a critical weld dimension that must always be clearly specified on the welding symbol.
This dimension will always appear to the left of the plug weld symbol and will always be preceded by the diameter symbol (Φ), leaving no room for ambiguity for any welding inspector or welder.
Understanding the Angle of Countersink
Some plug welds may require a countersink, which is an angled bevel around the top edge of the hole. This preparation helps ensure proper weld metal deposition and fusion.
The included angle of the countersink is specified on the same side of the reference line as the plug weld symbol itself, appearing either above or below the symbol. When plug welds do have a countersink, it’s important to remember that the specified size (diameter) of the plug weld is always measured at the bottom of the hole, not the wider top opening.
Indicating Plug Weld Depth of Fill
Not all plug welds are required to completely fill the hole and be flush with the surface or even have reinforcement. In many cases, a partial fill is specified. This is a common requirement in welding procedures.
If a plug weld is intended to only partially fill the hole, the required depth of fill is specified by a weld dimension placed inside the rectangle of the plug weld symbol. If no dimension for depth of fill is noted in the welding symbol, then the plug weld must be filled completely to the surface or with slight reinforcement. This ensures adherence to welding quality standards.
Spacing Between Intermittent Plug Welds
When multiple intermittent plug welds are used along a joint, their spacing – known as the pitch – is crucial for structural integrity and weld quality, helping to prevent weld failure.
The pitch (the distance from the center of one plug weld to the center of the next adjacent plug weld) must be specified to the right of the plug weld symbol. In such cases, it’s generally assumed that the plug welds are arranged in a straight line. If the plug welds are not in a straight line, the main part drawing or welding blueprint will provide the necessary dimensional layout.
Specifying the Number of Plug Welds
Sometimes, a specific quantity of plug welds is required along a joint or within a certain area. This is another crucial piece of information conveyed by the welding symbol.
When a precise number of plug welds is needed, the quantity must be shown in parentheses on the same side of the reference line as the plug weld symbol.
Contour Finish of Plug Welds
Just like with fillet welds and groove welds, plug welds may also require a specific finished contour: flat (flush), concave, or convex. This directly impacts the final appearance and functionality of the weld.
The same contour symbols and letter designations for finishing methods (such as grinding ‘G’, machining ‘M’, hammering ‘H’, or chipping ‘C’) that we’ve covered in previous sections are equally applicable to plug welds. For example, a straight line above the symbol with a “G” indicates a plug weld to be finished flat by grinding, a key detail for welding inspection.
Watch Our Video Tutorial: Plug and Slot Weld Symbols Explained!
For a dynamic visual explanation of plug and slot weld symbols, and to see these concepts in action, be sure to watch our accompanying YouTube video! It’s an excellent supplement for learning plug weld symbols.
Advance Your Welding Symbol Expertise Today!
Mastering plug weld symbols is a significant step in becoming a truly proficient welding professional. This specialized knowledge directly translates into better job performance, clearer communication on welding blueprints, and consistently high weld quality. It’s an essential part of any weld symbols cheat sheet for serious professionals.
Ready to enhance your skills even further?
- Download our FREE Fillet Weld Symbols Guide: Perfect for reinforcing your foundational understanding of fillet weld symbols and other basic concepts!
- Challenge yourself with our FREE Practice Welding Test: Assess your knowledge and identify areas for improvement, crucial for welder qualification and general expertise.
This information is derived from our comprehensive Welding Symbols Training Manual, available for purchase to those looking for even deeper insights into qualified welding procedures and advanced welding quality standards.
By expanding your understanding of AWS 2.4 welding symbols, you’re not just reading drawings – you’re mastering the language of precision fabrication. Keep learning, keep growing, and continue building expertise that makes a real impact!
REFERENCE:
