reducing reork and scrap in welding operations
3 Causes of Weld Quality Problems That Management Overlooks
When welds fail, the first instinct is to blame the welder. But here’s the truth: most quality problems don’t start in the weld booth — they start in the front office.
The best welders in the world can only do so much if management doesn’t give them the tools, instructions, and training they need. Let’s talk about three major hidden causes of welding quality problems that are rooted in management, not welders ability or attitude.
1. No Control Over Welding Procedures
Imagine asking ten welders to build the same part, but each one is allowed to do it their own way. The result is ten different welds, ten different levels of quality, ten different costs and potentially a lot of rework.
This is exactly what happens when fabrication shops don’t provide written, qualified welding procedures (WPSs). Without them, welders rely on habit or guesswork. Inconsistent heat input, travel speed, and even filler metal selection lead to unpredictable quality. Often, these problems don’t appear right away but show up later during inspection—or worse, in service.
The solution is to standardize welding with controlled, accessible procedures. A good WPS is like a roadmap. Without it, your welders are driving blind. Welding procedures don’t need to be restrictive either.  Codes like AWS D1.1 allow for ranges when WPSs dictate essential variables like amperage and voltage.
2. Lack of Clear Work Instructions
Even with solid welding procedures in place, welders still need clear work instructions tailored to the job. This is where management often drops the ball. Blueprints may be vague or incomplete. Critical weld locations sometimes aren’t marked. The sequence of operations might not be defined.
When instructions aren’t clear, welders are forced to interpret drawings on the fly. That leads to missed welds, overwelding, wasted time and filler metal, or wrong joint preparation altogether. The truth is, quality isn’t built on talent alone—it’s built on clarity.
Clear, visual, and consistent instructions prevent confusion and ensure that every welder builds the part the same way, every time.
3. Inadequate Training and Oversight
Many facilities assume that because a welder has years of experience, they can handle any job. But welding isn’t just about skill—it’s about matching the skills of the welder to the exact processes, materials, and procedures in use.
Without targeted training, welders often fall back on techniques from previous jobs that may not apply. They may not fully understand code requirements. Supervisors may not have the tools to verify if procedures are being followed correctly. The result is inconsistency that no amount of post-weld inspection can fully catch.
Consistently providing adequate training for welder typically results in less rework and thus, higher productivity by improving weld quality.
Consistently providing adequate training for welder typically results in less rework and thus, higher productivity by improving weld quality.  Don’t think you have much rework?  Start paying attention to how much grinding you do.
Training is not a one-time event. It should be ongoing, job-specific, and reinforced through oversight. When management invests in training, welders gain confidence, supervisors gain control, and the shop gains consistency.  An example of training that is hardly provided for welders is on the topic of metallurgy.  Welders understand that different metals can behave differently, but understanding the root cause behind issues for specific base metals can go a long way.
A simple example of this  lack of  metallurgy training is evident in fab shops that weld different metals.  You will often find that the same shielding gas, say 90% argon/10% carbon dioxide, is used on both carbon steel and stainless steel.  Welding stainless with 90/10 can produce a good looking weld, but the metallurgical consequences of this mistake come up much later, many weeks or even months after the part is put in service.  Understanding why the excess carbon dioxide in the mix hurts corrosion resistance would prevent this problem.
What can management do about it
The next time weld quality problems show up, don’t just ask, “What did the welder do wrong?” Instead, ask: Did we give them the right procedure? Did we provide clear instructions? Did we train them for this job?  Many fabricating shops don’t have any of these documents and processes in place.  This stems from management’s lack of understanding of welding processes, welding quality and welding economics.  Creating these documents doesn’t have to be complicated.
Establish welding parameters
Welding procedures can be developed even in shops that don’t have welding engineers or certified welding inspectors.  All you need to do is go out in shop and conduct a few weld tests, but rather than focusing exclusively on weld appearance try cutting open the weld to etch it.  Verify that it has the desired penetration and no internal discontinuities.  If that is the case, document the parameters that were used and that becomes your welding procedures.  This will not be a qualified welding procedure per AWS structural welding codes, but you will be further ahead than most fab shops.  It would be recommended to eventually progress to following codes such as AWS D1.1 for welding procedure qualification.
A good number of fab shops recognize the need for welding procedures, and they want more than just basic parameters. However, they may not have a welding engineer on staff or even someone with a sound understanding of welding processes and variables.  If you fall under this category you may benefit from   “Welding Procedure Development for Non Welding Engineers.” This is a step-by-step guide to help you develop welding procedures with confidence.
Work instructions can expand on your welding procedures.  A welding procedure, for example, can ask for a minimum preheat of 225F.  Are instructions provided for the welder on how and where to measure the interpass temperature?  Do they have the right tools (temperature crayons, pyrometers, etc.) and have they been trained on how to use them?   Many shops where preheating is common practice provide Tempilsticks to their welders. Tempilsticks  are temperature-indicating “crayons” that instantly melt and leave a distinctive mark on a heated surface when it reaches the stick’s melting temperature.  Very simple to use, that is, after you have been provided clear instructions.   Simple things like this are often overlooked.  Having work instructions should not be seen simply as documentation to meet certain requirements, but rather as a power tool to ensure quality and consistency.
Start by creating work instructions (or standard operating procedures) for repetitive tasks where you know you have variation from one welder to the next.  This can be preheating practices as we just explained, it could be in preparing a bevel for welding, or something a bit more complicated such as post weld heat treatment.
Provide training to your welders
Training is another component of the solution.  Even if you don’t have the expertise in-house you must have continuous training for your welders.  Many OEMs  and even some industrial distributors provide training and you should take advantage of it.  Sometimes it is free.  But even if you have to pay for training it typically pays huge dividends
Chances are, the root cause of most welding quality issues is management, not workmanship.
If you found this helpful, get more free welding resources here → Resource Library
Looking for ready-to-use welding procedures? Check out our collection of prequalified WPSs designed to save time and prevent costly rework.
