Why Exceeding Welding Requirements Can Lower Quality and Raise Costs
When “Too Much Weld Quality” Can Hurt You
We all want high weld quality in our operations. Nobody sets out to make bad welds. But here’s the truth: sometimes our efforts to increase quality actually reduce quality — or at least drive costs up without any return.
It’s important to always meet the required level of quality. That means your welds should pass your own standards, your customer’s acceptance criteria, or the expectations set by the industry code you’re working under.
But going beyond those requirements isn’t always a good thing. In fact, it often adds costs that you can’t recover in sales or profits. And worse, it can actually create new quality problems.
Let’s look at four common examples where trying to make welds “better” can backfire.
1. Overwelding: Bigger Isn’t Better
Many fabricators believe that making welds larger than necessary is a sign of quality. A bigger weld must be stronger, right? Not necessarily.
Once the maximum strength of the joint is achieved at the correct weld size, making the weld larger adds no additional strength. What it does add is:
  • More time to deposit the weld.
  • More filler metal and gas consumption.
  • Higher distortion risk.
In some cases, overwelding can double or even triple the cost of the weld. And distortion from excessive weld metal often creates rework or even scrapped parts. That’s not higher quality — that’s wasted effort.
2. Chasing Deeper Penetration
Penetration is usually a good thing. We want fusion between base metal and weld metal to avoid defects. But in some applications, deeper penetration is the opposite of what you need.
Take hard surfacing (hardfacing) as an example. The goal is to deposit a hard, wear-resistant layer. The deeper the penetration, the more base metal gets diluted into the weld deposit. The result? A softer weld than intended.
In this case, “more penetration = better quality” is a flawed assumption. Controlled, shallow penetration is the actual quality standard.
Deeper penetration into the root of a fillet weld adds strenght to the weld by increasing the effective throat and thus the effective weld area. However, the added strenght may not be necessary. When welding steels with high levels of tramp elements deeper penetration may cause certain discontinuities such as porosity. Deeper penetration does not necessarily mean higher weld quality.
As long as a weld achieves fusion to the root it will provide adequate strenght provided that the weld size is follows the recommendation on the design. Deeper penetration into the root of a fillet weld adds strength by increasing the effedtive throat and thus the effective area of the weld. Deeper penetration does not always equate to better weld quality.
3. Picking the Prettier Process
TIG (GTAW) produces beautiful welds. Smooth beads, perfect ripples — often referred to as “code welds” because of their consistency in radiographic testing. But TIG is also slow, expensive, and labor-intensive.
In many cases, MIG (GMAW) meets the acceptance criteria just fine. It’s 2–3 times faster, requires less skill, and reduces overall weld cost dramatically.
If the customer’s requirements are satisfied with MIG, then choosing TIG for appearance alone doesn’t add profit — it just adds cost. The weld might look better, but the shop’s bottom line looks worse.
GMAW (Mig) welds can have excellent bead appearance at fast travel speeds without compromis
GMAW (Mig) welds can have excellent bead appearance at fast travel speeds without compromising weld quality.
4. Always Matching Filler Metal Strength
A common misconception is that the filler metal must always match the tensile strength of the base metal. In reality, the correct filler metal depends on the application.
For high-carbon steels or certain joints, using an undermatching filler (lower tensile strength than the base metal) can actually be an advantage. For example:
  • Fillet welds and partial joint penetration welds can achieve strength through weld size, not filler strength.
  • Undermatching filler can produce a more ductile weld, reducing cracking risk.
By blindly insisting on filler metals that match base metal strength, shops often increase costs — and sometimes even hurt weld quality by creating brittle welds that are more prone to cracking.
The Bottom Line on Weld Quality
Improving weld quality is always worth pursuing when your shop is failing to meet acceptance criteria. But chasing quality beyond what’s required — overwelding, over-penetrating, over-polishing welds, or over-matching filler metals — just adds cost and often introduces new problems.
The real win is achieving the right level of quality: one that satisfies the governing code, meets your customer’s requirements, and supports profitability.
What’s next for improving weld quality
If you found this helpful, here are two ways to go further:
  1. Download our Free Welding Quality Checklist → Get it here
    A simple tool to help welders and supervisors catch problems before they become costly.
  2. Be on the lookout for our new Welding Quality Standard Template (launching Sept 29)
    A ready-to-use framework that not only satisfies documentation requirements but also gives your shop a system to cut rework and improve profitability.
