How Engineering Intent Gets Lost Between the Welding Procedure and the Shop Floor
Most welding procedures do not fail because they are ignored. They fail because the engineering intent behind them never reaches the people doing the work, mainly the welders. A Welding Procedure Specification (WPS) may be technically sound, approved, and readily available, yet still produce inconsistent results. Welders interpret it differently. Supervisors enforce it unevenly. Inspectors struggle to determine whether deviations matter. When this happens, the problem is rarely a lack of discipline. It is a breakdown in communication. This article is part of the Developing Welding Procedures in the Real World series, which examines how welding procedures are developed, implemented, and used in real fabrication environments.
The WPS Is the Primary Communication Tool
A Welding Procedure Specification (WPS) exists for one reason: to communicate how a specific weld is to be made. It is the single document that connects:
  • Engineering decisions
  • Production execution
  • Inspection and quality enforcement
If that communication is incomplete, unclear, or disconnected from reality, the results will vary—no matter how skilled the workforce may be.  There are many times when welders need to communicate vital information to welding engineers in order for welding procedures to be developed properly. The suitability of a weld made in accordance with a WPS can only be as good as the procedure itself. If the welding procedure does not clearly communicate what matters, compliance alone will not produce consistent weld quality.
Where Engineering Intent Begins to Erode
Engineering intent is established during welding procedure development. It reflects why certain decisions were made—not just what values were selected. That intent begins to erode when the WPS is treated as a list of acceptable ranges rather than a reflection of deliberate engineering choices. Common warning signs include:
  • Wide parameter ranges with no context (sometimes beyond what the code allows)
  • Variables selected to “cover all cases” (i.e. to allow all skill levels to be able to “weld”)
  • Procedures written to satisfy audits rather than production needs
When intent is not embedded in the procedure, interpretation becomes inevitable.
Welding Engineers develop welding procedures to meet both production and quality requirements.  Many times these procedures are modified or not followed by the shop floor due to issues in communication.
What Is Meant by “Engineering Intent” in a Welding Procedure
When referring to engineering intent in the context of a Welding Procedure Specification (WPS), this does not mean that the procedure should contain written explanations or justifications for each variable. A WPS is not a narrative document, and it is not designed to explain why decisions were made. Engineering intent exists before the WPS is written. It refers to the reasoned decisions made during procedure development—the choices that determine:
  • Which welding process is selected
  • Which base metals and filler metals are paired
  • Which ranges of variables are allowed
  • Which limitations are intentionally imposed
That intent is embedded in the structure and content of the procedure, not explained in words. In other words, engineering intent is communicated through:
  • The variables that are included
  • The ranges that are allowed
  • The limits that are intentionally tight or intentionally broad
  • The conditions under which the procedure is meant to be used
A WPS does not explain intent—it reflects it. When a procedure has been properly developed, the intent is evident in what the procedure allows and what it restricts. When it has not, the procedure leaves too much open to interpretation, even if it is technically correct.
Why This Distinction Matters
This distinction is important because confusion often arises when engineering intent is discussed as if it were additional documentation. It is not. Engineering intent is the upstream thinking that governs how the procedure is constructed. If that thinking is incomplete or unfocused, the resulting WPS will communicate uncertainty—even without saying a word.
The Gap Between “Allowed” and “Appropriate”
One of the most common sources of confusion on the shop floor is the difference between what is allowed and what is appropriate. Codes and standards often permit wide ranges for variables such as amperage, voltage, travel speed, or electrode diameter. A procedure may technically allow operation anywhere within those limits. However, not all combinations within those ranges produce equivalent results or even welds that meet the desired weld quality. When a WPS does not communicate which values were selected intentionally—and why—welders are left to determine what works through trial and error. Inspectors, in turn, are left enforcing compliance without understanding the underlying intent. This is how procedures become simultaneously “followed” and ineffective.
How Interpretation Replaces Intent
When engineering intent is not clearly communicated, several predictable behaviors emerge:
  • Welders adjust parameters to stabilize the arc or improve appearance
  • Supervisors tolerate informal adjustments to maintain production
  • Inspectors focus on measurable outputs rather than process control
None of these actions are inherently wrong. They are rational responses to unclear guidance. The problem is that once interpretation replaces intent, the procedure no longer controls the process. It merely exists alongside it.
Availability Does Not Equal Communication
Many organizations assume that making a WPS available is the same as communicating it. In practice, availability is only one part of the equation. Even when procedures are physically accessible to welders, problems arise when:
  • The rationale behind key variables is unknown
  • Important limitations are not emphasized
  • Tradeoffs between quality and productivity are not documented
A WPS that is available but poorly communicated creates just as much risk as one that is missing entirely. Clear communication is not about volume of information—it is about relevance and clarity.
Why This Becomes a Quality and Cost Issue
When engineering intent is lost, variability increases and quality issues arise. That variability shows up as:
  • Inconsistent weld profiles
  • Unpredictable penetration
  • Higher inspection rejection rates
  • Increased repair and rework
Corrective actions often focus on tighter enforcement or additional inspection. While these may reduce symptoms, they do not address the root cause. A procedure that does not communicate intent cannot be enforced effectively, and a process that cannot be enforced consistently will never be stable.
What Welding Engineers Do to Preserve Intent
Welding engineers recognize that the WPS is more than a record of variables—it is a communication document. They preserve intent by:
  • Selecting variables deliberately, not defensively
  • Limiting ranges to what is actually usable (i.e. AWS allows a +/- 10% variance in amperage, the welding engineer may choose a +/- 3% range)
  • Ensuring procedures reflect how welding will be performed
  • Validating assumptions before production begins
This approach reduces interpretation and increases repeatability. The goal is not to eliminate flexibility, but to ensure flexibility exists within intentional boundaries.
  • A WPS is the primary means of communicating engineering intent
  • Wide parameter ranges often invite misinterpretation
  • Availability of procedures does not guarantee understanding
  • When intent is unclear, variability becomes unavoidable
Additional Context
Clear communication through the WPS is essential for controlling weld quality, productivity, and cost. When procedures fail to communicate intent, even skilled welders and diligent inspectors are forced to rely on judgment rather than guidance. The structured approach to procedure development discussed throughout this series is documented in Welding Procedure Development for Non-Welding Engineers, which focuses on ensuring that engineering decisions are translated clearly into usable welding procedures. Reference: Welding Procedure Development for Non-Welding Engineers
