Ever felt like engineers and welders speak two different languages? It’s a common challenge in metal fabrication shops everywhere. Engineers design for strength, performance, and code compliance, while welders bring those designs to life on the shop floor. When these two vital roles aren’t perfectly aligned, it can lead to confusion, rework, and costly delays.
At Welding Answers, our goal is to bridge that gap. We believe that by understanding each other’s perspectives, both welding engineers, welding supervisors, welders, and even quality control personnel can achieve higher weld quality, reduce weld failure, and dramatically improve welding economics.
Our previous article “6 Things Welders Wished Engineers Knew About Welding” highlighted certain aspects of the welding profession that engineers are not always familiar or even aware with. This article will highlight 7 crucial insights engineers often wish welders understood better about the “why” behind their designs and procedures. Knowing these can transform your welding operations, boost productivity, and elevate your job performance.
1. Why WPS Adherence Isn’t Optional (It Saves You Rework)
You’ve seen those Welding Procedure Specifications (WPS) documents, right? Sometimes they might feel like a list of arbitrary rules. But for welding engineers meticulously develop welding procedures,, often following standards like AWS D1.1 and other structural welding codes, that dictates the acceptance criteria for welds.
Why so specific? Every parameter – from amperage and voltage to travel speed and shielding gas – is chosen to ensure the weld meets specific strength requirements, achieves optimal penetration, and avoids defects. Deviating from the qualified welding procedure can jeopardize weld quality, leading to rework, inspections, and even catastrophic failures.
Think of the WPS as your recipe for success. Stick to it, and you’ll consistently produce high-quality welds, saving everyone time and money.
2. Heat Input: Not Just a Number (It Controls Microstructure)
Engineers often specify either a minimum or a maximum heat input in the WPS. In many cases, the heat input is not noted on the WPS directly, but the chosen values for amperage, voltage and travel speed will dictated the actual heat input. For welders, heat input may not seem like a big deal as long as they can deposit a good looking weld with a good “heat signature,” but it’s far more critical. Heat input directly controls how fast the weld metal and the Heat-Affected Zone (HAZ) cool down.
Why is cooling rate so important? It profoundly influences the microstructure of the steel. Too fast a cool, and you risk forming brittle structures that are susceptible to cracking – even in seemingly common materials. Engineers calculate these limits to ensure the finished weldment has the desired mechanical properties and resistance to weld failure. In other cases, such as when welding austenitic stainless steels, a fast coolign rate is actually desired, as a slow cooling rate can lead to sensitization.
Understanding heat input helps you control the fundamental changes happening within the metal as you weld.
3. The Impact of Sequence on Distortion (It’s About Managing Shrinkage)
Distortion is a fabricator’s headache, leading to parts that are out of tolerance and require costly straightening or even scrapping. What many welders might not realize is that the welding sequence – the order in which individual welds or weld passes are made – is often engineered to minimize this problem.
As weld metal cools, it shrinks. Without a planned sequence, these shrinkage forces can pull the material out of shape. Engineers carefully consider these forces and design a sequence that balances them, much like playing a strategic game of chess. Following this sequence is key to keeping your assemblies straight and avoiding unnecessary rework.
For a deeper dive into fighting distortion, you might find our previous article, “3 Mistakes that Lead to Distortion”, helpful.
4. Preheat and Interpass Temperature: Your Crack Prevention Kit
Why bother with preheat and interpass temperature? These aren’t just suggestions; they’re essential crack prevention strategies, especially when welding carbon steel or high-strength materials.
Cracking, particularly hydrogen-induced cracking (also known as cold cracking), is a major concern. When you weld, hydrogen can get trapped in the molten metal. If the weld cools too quickly, this hydrogen can’t escape, leading to tiny, invisible cracks that can propagate over time and cause weld failure.
Preheating slows down the cooling rate, giving trapped hydrogen time to diffuse out of the weld. Maintaining a minimum interpass temperature ensures that subsequent weld passes don’t suddenly cool the previous bead too rapidly. Engineers specify these temperatures based on material thickness, chemistry, and joint restraint to ensure the weld’s integrity.
5. Material Grade Matters (Not All Steels Weld the Same)
You might see different steel grades come through the shop – from common A36 to specialized alloys. While they all look like “steel,” engineers select each material grade for its unique properties and how it will perform in service.
Crucially, how to weld carbon steel versus how to weld stainless steel (or other alloys) can be vastly different. Engineers understand that each material reacts uniquely to the heat of welding. For example, some steels are more prone to hardening or cracking in the Heat Affected Zone without proper preheat or controlled heat input. Using the wrong welding procedures for a specific material can lead to defects, reduced strength, or premature failure.
Trust that the material specified on the print has a reason, and if you’re unsure, ask!
6. The Role of Consumable Storage (It Prevents Hydrogen Contamination)
You might wonder why engineers and quality control personnel are so particular about how filler metals are stored. It boils down to one word: hydrogen.
Many welding consumables, especially low-hydrogen electrodes (like SMAW electrodes and some FCAW wires), are designed to minimize hydrogen in the weld metal. However, if these consumables absorb moisture from the air due to improper storage, that moisture introduces hydrogen into your weld pool. As discussed with preheating, hydrogen is a primary culprit for hydrogen induced cracking, a major cause of weld failure.
Proper storage (in heated ovens or sealed containers) is a simple but vital step in weld troubleshooting and ensuring optimal weld quality. It’s a small detail with huge implications for the finished product.
7. Your Feedback Is Invaluable (You See the Process Up Close)
This might be the most important point of all: Engineers genuinely value your input! While engineers spend their time designing and calculating, you, the welder, are on the front lines, seeing the real-world challenges and nuances of the welding process.
You notice if a joint is difficult to access, if a material is behaving strangely, or if a particular parameter consistently leads to issues. This hands-on experience provides invaluable feedback that can help engineers refine designs, optimize welding procedures, and ultimately improve the entire fabrication process. Good communication between the shop floor and the engineering office is the fastest way to solve problems, increase efficiency, and boost overall welding economics.
Bridging the Gap for Better Welds
Understanding these 7 points can significantly improve the collaboration between engineers and welders in your facility. It’s about recognizing that everyone plays a critical role in achieving high weld quality and maximizing productivity.
Want to learn more and continue improving your welding knowledge?
Download our Free Guides for Welding Professionals – packed with actionable insights you can use today!
Subscribe to our newsletter by adding your email in the box below to get our weekly articles and never miss our valueable and actionable content.
