Most fabrication shops don’t struggle with welding because they lack capability.
They struggle because of the decisions they make every day—especially when those decisions are based on habit rather than engineering and economics.
One of the most common examples is electrode selection. Many shops default to using flux-cored wire for everything, assuming it provides the best combination of quality and productivity. Others prefer solid (MIG) wire because it’s simpler and less expensive.
As discussed throughout this series, welding decisions should always be evaluated through two lenses: quality and cost. The choice between flux-cored arc welding (FCAW) and solid wire gas metal arc welding (GMAW) is a perfect example of how these two factors interact.
This article will break down where each process makes sense—and where it does not.
Understanding the Difference
Flux-cored arc welding uses a tubular wire filled with flux, while MIG welding uses a solid wire. That difference in construction drives everything else—from cost to performance.
Flux-cored wire is manufactured through a more complex process. A steel strip is formed into a tube, filled with alloying elements, and then closed. Solid wire, by comparison, is drawn from a solid rod. Because of this:
- Flux-cored wire is typically more expensive
- Solid wire is simpler and lower cost for standard applications
However, focusing only on price per pound misses the bigger picture. What matters is how efficiently that wire turns into deposited weld metal—and how it impacts your overall operation.
Where Flux-Cored Wire Makes Sense
Flux-cored wire has very clear advantages, particularly in certain applications where solid wire struggles.
The most important of these is out-of-position welding.
When welding out-of-position (vertical up or overhead), flux-cored wire benefits from its slag system, which helps support the weld puddle. This allows for higher deposition rates compared to short-circuit GMAW and makes it easier for welders to maintain control. In many shops, this alone justifies the use of flux-cored wire.
Another major advantage is related to welding codes. Under AWS D1.1, GMAW short-circuit transfer is not allowed for prequalified welding procedures. This creates a limitation when using solid wire out of position. Flux-cored welding, on the other hand, can be used in prequalified procedures, as it operates in the globular mode of metal transfer, allowing fabricators to avoid costly and time-consuming qualification testing.
Flux-cored wire also becomes more attractive in higher strength applications. As tensile strength requirements increase, solid wire becomes more expensive because the alloy must be built into the green rod (raw steel) itself. Flux-cored wire can achieve those properties by adjusting the flux composition, making it more economical at higher strength levels.
Where Solid MIG Wire Has a Significant Advantage
While flux-cored wire performs well in specific scenarios, solid wire offers several advantages that are often overlooked—especially in flat and horizontal welding.
The first is efficiency.
Solid wire converts approximately 98% of the electrode into weld metal. Flux-cored wire is typically around 85% efficient, with the majority of the remaining material becoming slag. This means that even if both wires cost the same per pound, solid wire delivers more usable weld metal and is inherently more economical.
The second advantage is productivity through reduced cleanup.
Because solid wire does not produce slag, there is no need for interpass cleaning. Flux-cored welding, by contrast, requires slag removal and carries the risk of slag inclusions if not done properly. This adds labor time and increases the likelihood of rework.
Solid wire also provides better feeding reliability. Its higher column strength allows it to feed more consistently through the welding system, reducing issues such as birdnesting and minimizing downtime.
Another important factor is hydrogen control. Solid wire, particularly with a copper coating, is less susceptible to moisture pickup. Flux-cored wire, due to its tubular construction, is more prone to absorbing moisture, which can increase the risk of hydrogen-induced cracking in certain applications. There are seamless flux-cored wires that help with this issue, but comes with a much higher price tag.Â
Finally, there are environmental and safety considerations. Flux-cored welding produces significantly more smoke and fumes than solid wire. This often requires additional ventilation, fume extraction systems, or personal protective equipment, all of which increase operational cost.
The Most Common Mistake Shops Make
The biggest issue is not choosing the wrong process—it’s using one process for everything.
Many shops standardize on flux-cored wire because it works well out of position. While this simplifies operations, it introduces unnecessary cost and inefficiency in flat and horizontal welding.
A more effective approach is to match the process to the application.
As a general guideline:
- If out-of-position welding is minimal (less than about 10%), solid wire is usually the best choice for the entire operation
- If out-of-position welding is significant, flux-cored wire should be introduced—but only where needed
Everything else should remain optimized for efficiency.
A Critical Detail Most Shops Overlook
Not all flux-cored wires are created equal.
“All-position” flux-cored wires (i.e. E71T-1) are designed with slag systems that support vertical and overhead welding. However, when used in flat and horizontal positions, that same slag system increases the risk of slag inclusions.
If flux-cored wire must be used in horizontal or flat welding, it is often better to select wires specifically designed for flat and horizontal applications (i.e. E70T-1), which have lighter slag systems.
What This Decision Really Comes Down To
At the end of the day, both flux-cored and solid wire can produce high-quality welds.
The real question is not which one is better.
The question is:
- Which one produces acceptable weld quality
- At the lowest total cost
- With the highest productivity
That requires looking beyond the electrode itself and considering:
- Deposition rates
- Electrode efficiency
- Cleanup time
- Rework potential
- Fume control requirements
- Code compliance
- Welder skill level
Too often, these factors are ignored in favor of convenience.
A Practical Starting Point
If you want to evaluate whether your current process makes sense, start with a simple assessment.
Download the Welding Quality Quick-Check Checklist to identify:
- Where productivity is being lost
- Where quality issues originate
- Whether your welding processes align with your applications
This is a fast way to uncover opportunities for improvement.
When a Checklist Isn’t Enough
If you are looking to go further and establish consistency across your operation, we created the Welding Quality Standard Template.
This resource helps fabricators:
- Standardize welding procedures and expectations
- Reduce rework and variability
- Align welding, inspection, and documentation
- Meet customer and audit requirements efficiently
It provides a complete, editable framework built around AWS codes and real-world fabrication practices.
Conclusion
Flux-cored wire is not inherently better than solid wire.
Solid wire is not always the right choice either.
The difference between efficient and inefficient welding operations comes down to how these tools are applied.
The shops that consistently improve quality and reduce cost are the ones that make deliberate, informed decisions—not the ones that rely on habit.
REFERNCES:
Welding Procedure Development for Non Welding Engineers
