Weld porosity is one of the most common—and most frustrating—weld quality problems in fabrication.
It appears across processes, materials, and industries. It may show up suddenly on a job that has welded successfully for years, or it may appear intermittently with no obvious pattern. When porosity occurs, the typical response is to start making adjustments quickly in an effort to “chase it out.”
Sometimes those adjustments work.
More often, the problem returns.
The reason is simple: porosity is rarely caused by a single variable, and it cannot be solved reliably through trial and error.
This article is part of the Practical Weld Troubleshooting in Production series, which focuses on diagnosing and correcting weld problems using a structured, repeatable approach.
Why Weld Porosity Is Commonly Misdiagnosed
Porosity is often treated as a shielding gas issue.
When pores appear, the first changes typically include:
- Increasing gas flow
- Changing gas cylinder
- Replacing regulators or hoses
While shielding gas problems can cause porosity, they are only one part of a much larger system. Focusing exclusively on gas often delays the real solution and allows the defect to persist.
Porosity forms when gas becomes trapped in the molten weld metal and cannot escape before solidification. That gas can come from multiple sources, many of which have nothing to do with the shielding gas itself.
Step 1: Identify the Type and Pattern of Porosity
Effective weld troubleshooting starts with observation.
Before making changes, determine:
- Is the porosity surface or internal?
- Is it uniform or scattered?
- Does it occur consistently or intermittently?
- Does it correlate with position, joint type, or base material?
The pattern of porosity provides critical clues. Random, isolated pores often point to contamination or handling issues, while uniform porosity may suggest systemic problems with shielding or parameters.
Skipping this step leads to guessing.
Step 2: Evaluate Contamination Sources First
Contamination is one of the most common—and most overlooked—causes of porosity.
Potential sources include:
- Oil, grease, paint, or coatings on the base metal
- Moisture on consumables or joint surfaces
- Rust, mill scale, or cutting residues
- Improper storage of filler metals
Because contamination is not always visible, it is frequently underestimated. Even small amounts can generate enough gas to create porosity, especially in high-deposition or high-speed applications.
Step 3: Verify Shielding Effectiveness, Not Just Gas Flow
Increasing gas flow is a common response, but more gas does not automatically mean better shielding.
When evaluating shielding effectiveness, consider:
- Gas type and composition
- Flow rate relative to joint geometry
- Torch angle and stand-off distance
- Drafts, air movement, or position
- Equipment defects (loose or worn connections, damaged o-rings, etc.)
Excessive flow can actually create turbulence and draw in surrounding air, making porosity worse rather than better. One of the most dangerous aspects of excessive flow is that most of the porosity it can generate will be internal porosity, meaning it cannot be seen from the surface. The surface of the weld suggests that it is a good weld and thus solidifying the incorrect assumption that higher gas flow rate is better.
The goal is stable, consistent shielding—not maximum flow. If your flow rate is adequate, but you are getting porosity, simply increasing flow rate will only put a bandaid on the symptom but will not fix the root cause of porosity.
Step 4: Review Welding Parameters and Technique
Welding parameters influence how gas behaves in the molten pool.
Variables to evaluate include:
- Arc length and voltage
- Travel speed
- Heat input
- Wire feed consistency
Long arc lengths, excessive travel speeds, or unstable wire feeding can all increase the likelihood of gas entrapment.
Technique matters as much as settings. Even a well-developed procedure can produce porosity if it is not executed consistently. For example, if a welder pulls a long arc it can lead to inadequate shielding of the molten pool and create porosity even though the procedure was adequate.
Step 5: Consider Base Material and Joint Design Effects
Some materials and joint configurations are more prone to porosity than others.
Factors to consider:
- Base metal chemistry and cleanliness
- Base metal heat treatement
- Joint fit-up and access
- Root openings and backing conditions
- Welding position
Porosity that appears only in specific joints or positions often points to joint-related causes rather than global process problems.
Step 6: Make One Change at a Time—and Verify
One of the most common troubleshooting mistakes is making multiple changes simultaneously.
When several variables are adjusted at once:
- The true cause remains unknown
- Temporary improvement may mask the real issue
- The problem often returns later
A systematic approach requires making one change at a time, observing the result, and documenting what worked and why.
This is how troubleshooting becomes repeatable instead of reactive.
Why Systematic Troubleshooting Prevents Repeat Problems
Porosity problems that are “fixed” quickly often reappear because the underlying cause was never identified.
Systematic troubleshooting:
- Reduces guesswork
- Prevents unnecessary changes
- Builds organizational knowledge
- Improves long-term consistency and weld quality
Over time, this approach reduces both defect rates and the time required to resolve future issues.
- Porosity is rarely caused by a single factor
- Shielding gas is only one part of the system
- Contamination is a frequent root cause
- Pattern recognition matters
- One change at a time leads to reliable solutions
This article is part of the Practical Weld Troubleshooting in Production series.
Practical Weld Troubleshooting in Production – Series Hub
Additional Resources
If porosity is a recurring issue—or if multiple weld defects are appearing across different jobs—a broader troubleshooting framework is often required.
Weld Troubleshooting for Non Welding Engineers was developed as a comprehensive reference that walks through common weld defects, their causes, and corrective actions using a structured approach that can be applied across processes and applications.
Need help troubleshooting weld and welding equipment related problems?
For more information CLICK HERE or the image below.
- Learn and follow the process used by welding engineers to find the root cause of welding problems and their solutions.
- This troubleshooting guide goes beyond your typical troubleshooting charts on the back of an owner’s manual. The goal is not just to help you solve a welding problem, but to teach the concepts and theory behind it. Understanding why a recommended solution worked is just as important as solving the problem.
- This guide addresses the most common weld discontinuities as well as the most common welding equipment problems.
- Use this publication as a training tool for welders, supervisors, inspectors, quality personnel and even seasoned welding engineers.
