Common weld discontinuities that pass visual inspection undetected
The 4 Most Common Welding Discontinuities That Pass Visual Inspection
One of the most persistent challenges in welding quality is that many serious problems are not obvious at the surface.
In the previous articles in this series, we established that welding quality is created through procedures, qualification, and process control—not inspection alone. Visual inspection remains an important quality tool, but it has inherent limitations that are often underestimated.
This article is part of the Welding Quality – From Inspection to Control series, which examines how welding quality is managed in real fabrication environments. The series hub provides an overview of how these topics connect and why inspection must be supported by upstream controls.
Why Visual Inspection Has Limits
Visual inspection is fast, inexpensive, and widely used. It is effective for identifying surface-breaking welding discontinuities and obvious workmanship issues. It can be performed not only by inspectors, but by welders, supervisors and other shop personnel.
However, visual inspection cannot reliably detect:
  • Subsurface discontinuities
  • Inadequate fusion beneath the weld surface (lack of fusion)
  • Insufficient penetration in groove welds
  • Metallurgical issues related to heat input or cooling rate
This limitation is not a failure of inspectors—it is a limitation of the method itself.
When visual inspection is treated as the primary quality gate, defects that affect performance can remain undetected until they cause rework, delays, or failures in service.
The external appearance of a weld provides clues as to its quality, however, a weld can look good on the outside and still have internal discontinuities that could constitute a defect.
Lack of Fusion
Lack of fusion is one of the most common and most serious welding discontinuities that passes visual inspection.
A weld may appear smooth and uniform while failing to properly fuse to the base metal or between weld passes. This is especially common when:
Because the weld surface can look acceptable, lack of fusion is often discovered only through destructive testing, volumetric NDT such as ultrasonic testing (UT) or radiographic testing (RT), or failure in service.
Most instances of lack of fusion occur at the root of the joint which makes it impossible to see just by visual inspection.
Similar to lack of fusioin are slag inclusions.  Slag inclusions occur in slag producing welding processes such as flux-cored arc welding (FCAW), shielded metal arc welding (SMAW) and submerged arc welding (SAW).  Slag inclusions, as the name implies, is caused by trapped slag inside the weld.  This slag in most cases creates lack of fusion and in more dangerous cases may facilitate the start of a crack.
Inadequate Penetration
In groove welds, especially complete joint penetration (CJP) joints welded from both sides, inadequate weld penetration can severely reduce load-carrying capacity.  Incomplete penetration results in a smaller effective throat.
Externally, these welds may appear to meet size and profile requirements. Internally, however, the root may not be fully penetrated due to:
  • Improper joint preparation including the presence of mill scale and other surface contaminants
  • Incorrect root opening or groove angle
  • Inadequate welding parameters
  • Poor access or technique
Visual inspection alone cannot confirm penetration depth.
Undersized Effective Throat
Excessive weld reinforcement can mask an undersized effective throat, particularly in fillet welds.
A large, convex weld may look robust while providing less effective throat than required. This condition often results from:
  • Improper electrode angle
  • Low heat input combined with excessive buildup
  • Inconsistent travel speed
The weld appears “heavy,” but its load-carrying capacity may be significantly lower than assumed.  Many times, fillet welds with excessive reinforcement are cold weld with lack of fusion.  It is important to understand, especially in fillet welds, weld size (as measured by visual inspection) is not alway a good indicator of weld strength due to the potential for internal discontinuities.
The red line represents the desired dimension of the weld throat. The weld's concavity creates a reduction in the throat dimension represented b y the green line. There is a reduction of about 50% in the load carrying capacity of this weld due to its extreme concavity.
Although concave welds can be detected with visual inspection, many go undeteced when the weld is measured with the incorrect fillet gage.  In the figure above the red line represents the desired dimension of the weld throat based on the achieved leg size (from the root to the toes of the weld). The weld’s concavity creates a reduction in the throat dimension represented by the green line. There is a reduction of about 50% in the load carrying capacity of this weld due to its extreme concavity.
Internal Cracking and Metallurgical Issues
Certain cracking mechanisms—such as hydrogen-assisted cracking or solidification cracking—may not be visible at the surface during initial inspection.
These issues are influenced by:
Without proper procedure control and awareness of material behavior, these problems can develop even when visual criteria are met.
Why These Discontinuities Are So Common
Discontinuities that pass visual inspection often occur when:
  • Procedures are written for compliance rather than usability
  • Joint details are difficult to weld consistently
  • Production realities push parameters to the edge of acceptable ranges
  • Inspection is focused only on final appearance
  • Welders ignore qualified welding procedures
  • Welding equipment is incapable of producing the required output
When upstream controls are weak, inspection becomes the last—and least effective—line of defense.
The Role of Process Control in Preventing Hidden Defects
Preventing these discontinuities requires control, not just detection.
Effective prevention includes:
  • Qualified or prequalified welding procedures that account for real fit-up and access conditions
  • Welding parameter ranges that produce reliable fusion and penetration
  • Welder performance qualification that reflects actual production joints seen in production
  • In-process checks rather than end-of-weld inspection only
When these controls are in place, visual inspection becomes confirmation rather than discovery.
Practical Tools to Reduce Quality Escapes
Free Resource: Welding Quality Checklist
A free Welding Quality Checklist is available to help verify key quality-related items before welding begins, during production, and after completion. The checklist is designed to catch common conditions that lead to lack of fusion, inadequate penetration, and other hidden defects before they become costly problems.
Welding Quality Control Standard Template
For shops experiencing recurring quality escapes, a checklist alone may not be enough. The Welding Quality Control Standard Template provides a complete, editable framework for defining how welding quality is controlled across procedures, qualification, inspection, and corrective action.
This template helps move quality control from informal practices to a documented, repeatable system aligned with AWS codes and industry best practices.
The Welding Quality Standard Template. It’s a complete, editable system that covers material control and much more—helping shops meet documentation requirements while cutting costs in welding operations.  Take your quality and your documentation to the next level.
